Re: Any ideas Captains
Hey Laura,<br />Not sure how you determined the cables were OK, but if you haven't tried this already,disconnect the linkage to the shifting arm and then try to engage forward/reverse by manually moving the shifting arm. If still no go, you'll probably need to drop the lower end and inspect. When you drain the lower unit oil, check it for any evidence of metal chunks, etc. If you find anything larger than grains of sand, stand by for heavy rolls. Good luck, hope it's just a linkage problem. <br />Backlash
