According to my chart, the 470 had a 1.84 gear ratio; while the 140 used a 1.98 gear ratio.
Since you put a 470 lower unit on there, you now have that gear ratio(1.84) and can use the prop better suited to that ratio(17).
You will need to run it and see if it performs within it's proper rpm range. The WOT rpm range you're looking for should be 4200-4600 rpm.
I think I got the rpm range right; or did I screw that up too? :faint2:
I took lower unit from 470 merc and put on 140 upper.
