Re: Any tips on removing the drain plugs on a Cobra?
Besides making sure the alignment is good, greasing the splines and checking the bellows, anything else I should do as far as annual maintenance while the drive is off? (I'll change the gear oil once it's back on the boat).
Thinking I might paint it while it's off as well.
Yep, picked up a gimbal alignment tool this summerYou should be removing the drive annualy anyway. Make sure you check gimbal alignment before installing.
