San_Diego_SeaRay
- Nov 9, 2014
- 346
I didn't do too much research and ended up buying four of these "Spindo" type repair sleeves. I'm concerned because the sleeve is not a tight fit over my 2.125" spindle, but the instructions say that it doesn't have to be a tight fit. I'm talking probably an 1/8" to a 1/4" of play. I guess the "sleeve" spins in concert with the grease seal? And the contact with the spindle occurs on the inner rim of the sleeve? This kit uses a sleeve, an O ring, and a hefty and solid grease seal that's beefier than regular grease seals. Whatever this is, it doesn't seem to be common out there and I don't want to install something that is an untested or unpopular solution.
Here's a link to the product I'm referring to.
Anybody with experience with these? Thoughts?
