Anybody know what this is?
BWR1953
My buddy just got a new-to-him jon boat and it has 2 of these, one on each side of the boat near the gunnel, but not directly across from one another.
IslandExplorer
Looks like they were meant to have carriage bolts. The 8 sided star shaped holes would lock in the square portion of the carriage bolt nicely. All holes having the same punch instead of round hole is sometimes just bc it was cheaper to bang out at the factory that way. So my best guess is some sort of Chinese biminy/blind/rod holder brackets.
StewartL
Those are rod holders. They're for securing fishing rods while trolling or to keep them out of the way. Their offset placement helps with balance and prevents lines from tangling.
cyclops222
Those pointy edges would destroy the rod grip material in 1 trip. I vote for a set of top arched poles. Those teeth prevent the poles from rotating.
airshot
Had to take another look see.....pole holders were probably right, my first thought when I saw the pic was they were on the bottom of the hull, not the side ! Guess at my age, I can declare a " senior moment".....best excuse I can come up with !!
annabethgrigsby
你朋友拍的这张照片看起来像一个船用系缆桩,用来系绳。不过,这个设计挺独特的。上面有星形孔,看起来是为了减轻重量,或者方便固定一些特殊配件。建议你多拍些照片,说不定能找到更多线索!
我的朋友刚刚买了一艘新的平底船,船上有 2 个这样的船舵,分别位于船舷两侧,但并不直接位于彼此的对面。
guy48065
Exactly.
tg3690
Google Translate.........
The photo your friend took looks like a mooring bollard, used for tying ropes. However, the design is quite unique. The star-shaped holes appear to be designed to reduce weight or allow for attaching specialized accessories. I suggest taking more photos; you might find more clues!
Kinda sounds like a Chinese chat bot.......
dwco5051
I had something similar on a boat years ago. The actual rod holders slipped into them and the star shape let you change the angle depending how you placed them in. Not exactly the same as both the bases and the holders were plastic but the same idea.
redneck joe
That was my second guess, after the alternate universe portal. My remembery told me I had a boat with that set up.
