anyone had a pain in your arm ?
Drowned Rat
Re: anyone had a pain in your arm ?
Tylox is the same thing as Percocet. That's about as strong a prescription pain killer as you can get. BTW 3 of those bad boys is at the toxic level. Be careful, or you'll need more than a orthopedist.
xtraham
WranglerCarl said:
Sounds like this could be the carpel tunnel thing where the nerves are compressed in the carpel tunnel of the wrist. These nerves go from the fingers to your shoulder. Are your fingers going numb and you have a burning sensation of the hand and fingers ?? Is it really bad at night ??
I have had this for years and my daughter had surgery for it several years ago.
One thing you could try is to get a brace that straps around you wrist and keeps your wrist from bending and clamping down on these nerves. Wal-Mart sells these for around $10. It slips over your hand and It has a metal spoon that goes in your palm and velcro straps that go around your hand.
Hope this works....
no numbness, just pain and very weak, I tried elbow braces and wrist braces, didn't help, but the elbow brace helped remind me not to straighten it out, seams to feel better if I don't straighten it out completely
aspeck
Pain is what tells you that something in your body is not right and should not be used! Pain killers dampen that ability and cause you to use something you should not be using! They mask the symptoms, are not the cure.
If it is bad enough that you need the pain killers, keep pressing your doc, or see another doc. You could have something serious. It could be the head of your radius has broken off - any falls recently? There is a nerve that goes across that area and will effect the wrist area. Also, the radius can migrate back towards the elbow, restricting range of motion to the wrist.
It could be nerve damage, it could be vertibrae damage, it could even be cancer. There are so many things it could be, and there - don't mess with it, and don't wait.
drewmitch44
i dint think soo
oxy cotton 80 is about what you can get is much stronger
drewmitch44
tylox is not the same as Percocet at all it has the same amount of acedominifen but not the narcodic.
drewmitch44
i have been prescribed all kinds of pain killers. I have some conditions that id rather not mention. and Oxycottin is by far the best and usually are prescribed to the terminally ill. I have let these go to friends that snort them and thats what drug stores get robbed for.
BoatBuoy
Wrong.
tylox-5mg oxycodone, 500mg Acetaminophen
percocet-5mg oxycodone, 325mg Acetaminophen
drewmitch44
wow 5 mg so my script is 10 mg oxycodone i get 90 every 2 weeks. and then i get the 7.5's oxycodone with 325 MG Acetaminophen for breakthru pain. 60 a month. I was getting the morphene lollypops on top of that but they discontinued them. now im getting 80 MG oxycottin 3 a day. I cant take 3 a day i itch too much!!!
xtraham
aspeck,
no falls, just in my line of work my arms get pretty abused.
seems like using an impact gun really disturbs it...
also have a boss that's a *** and he doesn't think going to the doc as long as I can use it is acceptable
good advise thanks
Drowned Rat
BoatBuoy said:
Wrong.
Anyway, that's why I mentioned it. 1500mg of APAP is TOO much. You can fry your liver.
Dang Drew, are you okay? I'm surprised you're awake enough to type with that much dope on board. Just kidding. I know pain sucks.
steve201
xtraham
I have the same thing...called tendonitis and I have it in both arms right now..there are two things to do...heat therapy and also get one of those elbo braces made of nylon and stretches.....that will help...but really tain't much you can do about it......been to alot of doc's and they tell me the same thing....good luck...
Vlad D Impeller
It appears that you're in need of an amputation, other than that get yourself an appointment with a bone specialist as early as possible.
I hope that your arm gets well soon.
treedancer
To many long nights on 40//80 meter CW will cause repitive motion injury, are so I’ve heard.:%8)
xtraham
now we might be "hitting" on something here........
maybe I should slow down to about 40 wpm ;)
bjcsc
Best of luck to you xtraham...my father always said 45 was the age when you get a pain and that it just moves around from place to place from that day forward...
xtraham said:
thanks guy's
gonna give it a couple of weeks then go see a ortho..
Actually, you will see an ortho...
and you should do it now. Not wait.
