Anyone Own a Wooldridge Sport 2000 or Sportstour?
sep
I'm considering buying either the 20' Sport 2000 or the 20' Sportstour. Most of my use will be with an outboard jet running shallow rivers and a couple times a year I'll run in saltwater. I'd be interested to know what size engine most folks use on this size boat and how's the performance and fuel consumption.
kayak99
Re: Anyone Own a Wooldridge Sport 2000 or Sportstour?
If it helps, I run a 16'6" Wooldridge Extra Plus with a 115/80 Mariner. The best I get is 39 MPH and roughly 3 MPG. On plane I can run in 4 inches of water.<br /><br />You would probably want at least a 150/105 HP but you can put up to a 200 HP on your boat. Your speed will be greater than mine but fuel economy should be about the same although if you get a 4 stroke it might get a little better MPG.<br /><br />Getting a stainless steel impeller (with four fins as opposed to the aluminum 3 fin) will give you better hole shots.<br /><br />I never run salt so I can't help you there.<br /><br />A Wooldridge is a great boat and extremely durable.
