bollerwagon
- Oct 15, 2020
- 102
I´m looking for (idealls) full set of closed cooling system for my 5.7 GXi, anyone has that laying around? I mean it´s better selling it than havint it blocking your garage...
it takes a bit to find hoses that will fit. the Gates molded hose catalog has pictures and dimensions.I thnk I am too clueless to find the correct piping, so I was looking for a full set, mo problem it it is used as long as the parts can be reused.
sorry, this is a misunderstanding. I mean the full kit (all the parts) for a half system (just the engine fresh water cooled).Volvo Penta does sell many motors with a half system. Never looked if they sell the complete kit as an aftermarket
just a typical SBC hot-rod aluminum housing.What did you use as thermostat housing?
it doesnt need to be more complex than what you outlined in the beginning.I think I begin to understand how a closed cooling works now. For the old engines you basically just need a HX with 5 openings. - - Raw water in
- 2 x Raw water out to the exhaust
- Fresh water in
- Fresh water out
With this setup you can youse a simple automotive water neck and thermostat housing.
But the MPI has a more complex thermostat housing design, not so sure yet why. Also we need to connect the water cooled fuel pumps.
No, your current thermostat housing is a mix valve housing (mixes incoming water with the hot water to maintain block temp while keeping constant flow to the exhaustso i could even use my standard thermostat housing and block the ledtover connections?
still trying to understand the mechanics: in the raw water cooled engine I have the impeller pump, that pushes water into the engine and also the pump that circulates the water in the engine, pushing it through the collectors in the exhaust.
In the freshwater cooled engine, the circulation pump only moves the water around in the engine, while the impeller pump has to do the jop alone of pushing the water throught he HX and the exhaust.
Does that work if impeller pump and hose diameter are the same?
here is your volvo penta 271C setup (regardless if you are running the stock carb or EFI)still trying to understand the mechanics: in the raw water cooled engine I have the impeller pump, that pushes water into the engine and also the pump that circulates the water in the engine, pushing it through the collectors in the exhaust.
