Omineca
- Aug 22, 2021
- 60
I have a new to me AQ130C with a known leak from the heat exchanger system. I piped in smoke from a smoke generating leak detector via the exhaust output pipe (whatever that is called), and soon found an obvious leak. But then I saw smoke coming out of both carb inlets (arrowed in the picture).
I am more than a little sketchy on how this sytem works, so I would be grateful if someone could tell me if this is normal. I guess the exhaust and coolant outlet both come out the same pipe, so the combustion and coolant flow must link up somewhere, but I would really like to hear from someone who knows the answer to this!
