aq211a sp converting points to electronic ignition
jfalco
whats the best kit for converting my points distributor to electronic ignition, has anyone converted their distributor and are you happy with the results
Alan Lloys
Re: aq211a sp converting points to electronic ignition
I have converted my AQ125B from points to electronic ignition using a Pertronix kit.
I am very happy with it. It made the engine run much smoother and idle better.
The installation was relatively simple - just need to connect a few wires.
The only issue I had was that the timing was way different than the points so I had to play around with moving the distributor shaft one tooth. In the end I extended the timing bolt slot about 1/4" so it can be adjusted for the Pertronix or points.
I keep a set of points on the boat for an emergency spare.
I recently worked on an old AQ125A engine and replaced the points with the hot-spark module. This is similar to the Pertronix unit but at 1/2 the cost. Although it appears to work fine it just does not seem to be the same quality as Pertronix. And the instructions leave a lot to be desired in comparison. I would have struggled a little had I not seen the Pertronix instructions.
So it was fine for me to get a bench engine running for a test but I will stick with Pertronix for my actual boat engine as I feel more comfortable with it.
jfalco
thanks for your response, did you have to remove distributor or can i install with dist. in place?
Mullin
I did the hot-spark kit in my aq125a. Awesome. I set the gap and dwell on the points and it never ran this good. Just now on my second year with it.
I didn't remove the dist, did it in place.
Buy a new coil while you are at it.
You'll need a timing light and some TIM (thermal interface medium). I had some from working on pc's but you can get it at radioshack or pc stores, it didn't come in the kit.
Don S
There is a big difference in the distributors between the Volvo 4 cylinder OHC aq125 and your Chevy V8 aq211.
You may be able to install the kit without pulling the distributor, but you are still going to need to re-time it with a timing light.
jfalco
thanks don
