AQ231B needs new impeller...
ftl900
I know my motor has a raw water pump mounted on the front of the crankshaft. My question is, does it also have an impeller mounted on the outdrive lower, as in many other I/O models?? Or does it just pull water in via the crank mounted pump, and spit it out with the exhaust?
I have looked over the diagram for the lower and don't see anything like that at all, but I want to be sure I'm not missing something.
ftl900
Re: AQ231B needs new impeller...
Anyone???
1 impeller, or 2?
I know there's one on the front of the engine, but is there another impeller in the outdrive as well?
captmello
Anyone???
1 impeller, or 2?
one impeller in the crank mounted pump only.;)
ftl900
Thanks- I suspected as much, but I wasn't sure, and we're trying to resurrect this old 1988 and get it on the water.
