aquasport 175 osprey
mickyryan
I hate going to boat ramp from momorial day to labor day nothing good goes on there till the certain types of boaters stop boating...
mickyryan
gave up on crabpots the commercial guys just keep cuttiing them and they dissapear
mickyryan
Well no go on splash 2 carbs don't seem to be feeding fuel it sat for 4 months even with seafoam in the gas it appears these two carbs are acting up , I cleaned plugs refired back up only wants to run on top and bottom cylinder it is getting spark to these two cyl I checked that and the plugs weren't wet , dry as a bone so I'm guessing carbs gummed up again or something
mickyryan
Cleaned offending cylinders carbs runs much better idles about 1300 on muffs still a lil rough running might need to pull other 2 carbs and do a quick clean on them
mickyryan
These carbs have a history of dust clogging them, lol they say only real way to deAl with these carbs is to run hell out of boat to keep flow through them no matter they are pretty easy to tear down, almost like they knew it was going to be a issue and built them as such, also I was told they went to injection 2 years later then stopped making the 100 since they had a 115 and a 90 that seems like most gravitated towards those two options
mickyryan
Yaay I can sync carbs again, last one I had I used on a Pontiac 421 with 3 duices, didn't have any metric connections , this one set to go (posted on the other boat post and tried moving post here
mickyryan
Well I'm feeling a lil foolish but they prolly needed rebuilt anyways , gas was bad
kcassells
"O" I wish I could get my numbers down to that. Looking good Mick!
