Hi, everyone,
I have a Capri 1700 on which I'm running a 1987 125. The guy I got it from some months ago also threw in the 1989 Force 85 he had. The 85 needs powerhead work, but I took it anyway.
Running my boat recently, It dawned on me that the shaft is pretty long and the prop hangs well below the keel. Upon comparing it to the 85 I still have, there is a difference of five or six inches when measuring from the prop shaft centerline to the base of the powerhead.
As a result of this, I seem to be dragging the engine frequently in Charleston Harbor during low tide.
I have looked at the various options such as jack plates and just filling in the transom notch to raise the mount. All these seem either too expensive, complicated, or too unreliable.
Next I wondered if I can simply swap the powerheads and use the 125 head with the 85's lower unit. It seems to be in good shape. Are there any opinions on this matter? I am open to ideas as I think my boat will perform better with less mass hanging in the water. Not to mention that it seems to sit pretty low to begin with.
Thank you for your insight and guidance.
Bryan
Bryan
