ARE HT LEADS COMMON PROBLEM ????
daviddustyy
me again!<br /><br />Are the ht leads a common problem as i still have a loss of power and the engine surges under load <br />it will not rev right up when given full throttle<br />and when you go flat out it holds back but seems intermitent but seems fine out of water and has no idle problems.<br /><br />all ok<br />carbs checked.<br />spark checked when out of water.<br />fuel lines and tank.<br />timing.<br />all electric wire conections.<br /><br />or could it be the coil packs $$$<br /><br />the engine is a Mariner 50 1991 ish
rickdb1boat
Re: ARE HT LEADS COMMON PROBLEM ????
Put a timing light on each wire, one at a time, and have someone run it at night while you look to see if you are getting consistant spark on all cylinders when this problem occurs.
WillyBWright
Replace them? Ignore them? Buy another motor and let somebody else worry about them?<br /><br />Put an ohmmeter on them and see if they have continuity. Look at the insulation for damage. With the motor running, run a grounded 12v test light along them to see if they arc anyplace (you won't blow the bulb in the test light).
daviddustyy
thats excellent advice thanks for that sir i will do it right away!<br />i think thats the best idea i have ever had on here<br />why didnt i think of that??<br />i will let you know how i get on <br />thanks again!!!!!!
