Lowes and HD will have the regular Exterior grade plywood. the stuff you gave the link to says 'pressure treated'. So you can assume it will need to be dried out for a while (months). the regular exterior grade can get you going right away, if that is a requirement. PT wood is nice as it will not rot if it absorbs water.
Look for the APA rating stamp on the plywood . . .
'Exposure 1' = Not so good for the boat
'Exterior' = fine for the bat
'Marine' = great for the boat.
so, your best bet might be exterior and just try to get the best exterior grade they have . .
What kind of boat is this? How old is she? How big of motor? How is it used? How is it stored? What's your expectations for longevity? Got any Pics? Lots of methods for doing lots of things. It all depends on what you REALLY want to get out of your efforts. Thompsons is NOT a good idea for Anything!!!! Paint WILL work and last several years if you maintain the boat well and keep her covered at all times when not in use. Got an uncle with a Painted Plywood wood boat that's 40 years old and she works just Fine!!! No Epoxy or Resin of anykind on her. She's not even cared for that well. Leaned up against the barn with a oil soaked canvas tarp thrown over her. Prolly got 20 coats of paint on her!!!!If you have a tendency to abuse your boat and get her wet a lot and keep her wet then you're gunna need to seal her up really well. If not then lot's of other methods come into play. We here on the forum have a tendency to "Over KILL" a lot of things. I'm as guilty as anyone of this. If you're just wanting a utility fishing boat and wanting it to last a few years Knowing that you'll have to do it again later or move on to another boat then yeah, you can use a lot less expensive and time consuming methods and still be safe and sound with your build. Post up some pics and show us what your're working on and tell us exactly what you're trying to acheive. That's this Old Dumb Okies thoughts.
The Plytanium plywood will work. You're description leaves me a bit skeptical of her overall condition. I'd really like to see pics of her once the deck has been removed and we can see the condition of the foam and stringers. What Year is she??
tpenfield...the Plytanium plywood is rated interior/exterior. It does in fact use the appropriate glue in it's laminations.
Could someone please tell me if the paint idea or water sealer idea would work and if there are any other alternatives?
Please don't tell me that I need to just DEAL with the cost of 4 gallons of epoxy bc I know there has to be other ways and it is out of my budget. I don't need the floor to last 10-20 years either. I will probably upgrade in 5 or 6 years.
Yes, understood . . . I was concerned that the OP understood that there is - Pressure treated - , - Exterior grades - and - Interior grades - to choose from and that he should avoid any strictly Interior grade as a choice, given that he listed "Indoor Plywood" in his materials list subsequent to your posting about the Plytanium brand.
BTW... 4 gallons is a LOT of resin! If you need that much to glue down a deck and cover it you must have a pretty big boat.
