Well if any of you where following my posts on Help with Injectors. I have been having a low rpm 1998 225EFI running really rough below 2k rpm the whole boat shakes! I have tried almost everything and do not know what else to do.
Here is a list of what I have done.
1) Removed all fuel injectors sent out and cleaned and bench tested 2 times!
2) Cleaned filter in VST tank
3) Cleaned Filter in fuel pressure regulator
4) Cleaned fuel filter on side of motor
5) replaced water/fuel inline filter
6) replaced all 6 spark plug caps and spark plugs
7) replaced the o2 sensor and cleaned all parts.
8)checked all electrical conectors
9)put in enzyme fuel additive
My Yamaha mechanic suggested getting a spay bottle with some gas in it, take off the air silencer, have some one drive the boat and spray gas into one cyl at a time to try to find the bad one?
I am ready to dump it and look for a used 4 stroker over the winter.
