auto vs marine
lynnboy021
my friend is going to need a lower end for his 89 merc 5.7 but he has a 91 350 for a truck can he use it but just change out the cam?
Raystownboater
Re: auto vs marine
Im sure you will get a more qualified individual to answer this but from what I understand, the truck motors are what companies like Rapido use to build their marine engines and what is consistently recommended when building a marine engine
fastimz
Re: auto vs marine
He will need to change the cam adn the head gaskets to Stainless steel. He needs to make sure he uses all the marine add ons, (alt, dist, starter, coil, carb, etc.) The heads will ofter have bronze valve guides.
Re: auto vs marine
Ayuh,... If he ain't playin' in the Brine,...
I'd run it the way it Is...
