B3 question
ericcarr2000
Ensign
I purchased a new bravo 3 drive along with a set of b3 prop set. I do have the retaining nuts for the props, however, is there some sort of a washer I need for them?
alldodge
ericcarr2000
Ensign
I believe I have them on the drive. What I'm talking about is where the nuts tighten, on that side of the prop.
alldodge
Sorry, if I'm not understanding, but "where the nuts tighten"
The thrust washer goes on, the front prop goes on, then the 2 3/4 nut goes on and tighten it down using something like a 2x4 between the cav plate and the prop. Using the 2x4 keeps the prop from turning while it is tightened.
Then repeat with the rear prop
and don't forget to put grease on the prop shaft
ericcarr2000
Ensign
Gotcha, I thought there might be a washer of some sort that went on after the prop was on.
