Back of trailer hitting the floor
GA_Boater
18 months ago we asked for some pictures! Are you going let us help you?
Without pics, none of us can offer any help
daddie05
I found out what is making the trailer so low from the back. Check this youtube link that I uploaded
I need suggestions because as soon as I lower the jack, the trailer suspension moves. Thanks!
GA_Boater
The eye bushing is either broken, missing or the spring eye is broken. Compare the spring eye with the other side, you may need a new pair of springs.
daddie05
Both sides move when I raise/lower the trailer. Neither has the bushing inside
daddie05
That is normal for a slipper type spring. Not saying that your spring isn't worn out our undersized but what you are showing is how a slipper spring works.
http://www.easternmarine.com/Open-Eye-Slipper-Trailer-Leaf-Springs/
Mine definitely aren't these leaf springs. Both my springs have an eye on both ends. I never paid too much attention to the trailer until I noticed it grazing the groundwhen pulling into driveways. It's gotten far worse where i can't get it out of my own driveway.
bruceb58
Show a video of the other side when you place weight on it.
So does the other end of the spring use a shackle like this? Normally the shackle is towards the rear of the trailer as shown in this diagram if you have a double eye as you just stated.
bruceb58
On my Wellcraft's trailer, I have an open eye slipper spring on it and it looks identical to what you have. Mine is a tandem.
