backfire mercruiser
chesire
Re: backfire mercruiser
Talking to a wall? :mad: I was just responding to ariverrat's post. I have been following trents advice I ordered a gasket kit for carb, received it today, also bought a new dist cap. It is pouring out today so I can't work on it hopefully later or tomorrow I can get to it. <br /> Trent any idea how I can get service bulletin for gasket problem?<br /> Thanks Riverrat! I have been told(in the past few days) that the low compression on 2 adjacent cylinders is a sign of a blown head gasket. but have not heard of it causing the lawnmower effect lol. :eek: How can that be checked without tearing apart the engine? how involved is replacing the head gasket? :confused: does engine have to come out of boat? :confused: <br /><br /> Thanks again you guys are the best!!!<br /> but thats coming from a wall so....
denniz
Didnt mean to offend . You could easily have a bent push rod. have you taken the valve cover off? Checked for loose rockerarms? Done a fuel sample to see if its water in the fuel?....?????Wasnt refering to you directly when I said talking to a wall. There are a few people on this forum that know their asz from a hole in the ground.. There are alot that DONT. Just because someone owns a boat doesnt mean they know how to work on them. Ive worked on boats for 20+ years been certified for 15 years, probably could diagnois your problem in fifteen minutes If I had your boat. Goodluck
chesire
I wasn't offended rod I empathize with you I Just was pointing out that sometime the walls have ears.(lol jokeing I also know that I am by no means a mechanic more or less a certified marine mechanic! and I do appreciate all of your and all others time in helping us poor slobs out. I am a boat owner, just not a rich one so if I can fix myself i want to. Not only that but if i do have to take it to one of you guys I want to know what the problem is before I take it, not all in your profession are honest. I really do take all of the advice I get and appreciate it MORE than I could ever tell you.
chesire_catt
OK I cleaned the carb and reinstalled still backfiring. Any thoughts on the headgasket? How can I check without tearing apart the engine? Is that a big job should I ahve it done? will I need to pull valve cover and exhaust manifold? thanks again
denniz
OK did the simple thing first. Good, next id pull the valve cover and make sure you dont have a bent push rod. Re run compression test first. Any signs of water in the cylinders? (=higher compression)
chesire_catt
got home from work around noon thunder and clouds for the last two hours 1/2 hours but no rain dont think i want to chance it. Funny thing is Im putting a sprinkler system in my yard too when there is no rain. has rained almost every daY the last few weeks. <br /> Rod I dont know what a push rod is or how to tell if its bent where can I see 1 online? <br />Thanks again
denniz
Ill help all I can but it sounds like you need to take it to a shop. If you dont know what a bent push rod looks like ( and im truly not being sarcastic) you could waste your whole summer jacking with this. Bring it to TEXAS and ill fix it for you.
