ShellBack89
- Feb 18, 2012
- 211
Took boat out this past weekend. Had her running several times before taking her on the water at idli and was fine. Once on the water ran awesome for about 10 minutes then heard a backfire. She then began sputtering and died. Refired a couple of times but same thing. Good thing for Vessel Assist :facepalm: Once back on my trailer she fired up and ran at idil and even revving her up to 2500 RPMs and sounded good. Did the same thing when I got home
Thought (still could be) bad gas. Gas is several months old (1/2 tank) and then I added super to fill off the tank. Today I pulled the fuel line to the carb to see if the strainer was clogged and it was bone dry. I then tool the bell housing off the fuel pump to replace the fuel filter and same thing bone dry. I turned her over to see if any gas would come out of the fuel line, nothing. Pulled the fuel line from the tank and there doesn't seem to be a blockage.
Thoughts.......
1. Bad fuel pump which needs to be replaced
2. Bad fuel which needs to be pumped out
3. Clean flame arrestor
4. All of the above
Thoughts.......
4. All of the above
