backfire while opening throttle
freddyray21
I got a backfire through the carb when opening up the throttle from idle to wot. It backfires then takes off and runs. I am thinking the advance is not working properly. I have 1972 120hp Mercruiser running points (new with dwell at a steady 30 degrees), new cap, rotor, plugs and wires. Seems to overcome the backfire and run, but I could do without the hesitation when pulling a skier up. Fred
lilmandavis
Re: backfire while opening throttle
accelerator pump might not be workin right. go electronic
bamadave
lilman, what the heck is an electronic accelerator pump?
lilmandavis
dont you know?!? electronic pickup in the dist. oops!
freddyray21
accelerator pump is working fine. When I pump it I get a good stream of gas. Could it be I have it too lean on idle. I had to lean it out a lot to get it to idle down. It runs smooth on idle, but each screw is only open about 1.25 turns.
freddyray21
lilmandavis
yes its possible. when setting the carbs i set the idle with the set screw. after i get a proper rpm like that, i turn the jets till the motor starts to idle down. after the engine has a slight change i turn the screw out 1/8-1/4 turn. make sure both jets are in sync, you surely dont want to run lean
