backwards steering
jlauritsen
I just bought a '93 Sylvan fishing boat with a 75 Mercury, the previous owner had a new helm and steering cable installed but it steers backwards, how big of a deal is it to fix it
Laddies
Banned
Re: backwards steering
The helm need to be taken off and turned so the rack attaches on the opposite side from where it is to fix the problem.
ezmobee
Laddies nailed it. Very common mistake and very simple (4 bolt) fix.
Don S
If you have rack steering, it's more than 4 bolts. You can take the rack cable off with 4 bolts, but you have to disassemble the helm unit and turn it 180? and put the rack back on.
The rack has to be on top of the helm unit as shown in the picture below.
southkogs
... figure it out before you put it on the lake. Otherwise people look at you kinda' funny.
Ask me how I know :rolleyes:
jlauritsen
Thanks everyone for your replies I just looked at it and it is a Teleflex Rack System. It looks like a tight fit and some cutting was done when this system was installed. The previous owner told me it had a tilt wheel in it but the cable had frozen up. It looks that more cutting of the dash supports will have to be done to put the rack on top of the helm.
Captain Caveman
It's worth addressing the issue, because in an emergency situation you don't want to turn the wrong direction by mistake!
jlauritsen
I did not do a water test on the boat. I purchased it from a friend and he told me about this before I bought it. It was an easy fix and I thank everyone who helped me out.
JoLin
Take a real close look before you go cutting anything. I have a '95 Sylvan 16 Pro, dual console. It CAME with a Teleflex rack system. I had to replace the cable. It was an absolute bear, but I didn't have to do any cutting. Maybe the P.O. cut things because he had to in order to install it INcorrectly. PO's do weird stuff...
