Ok I had a problem with my 1970 60hp Johnson again. I normally start my motor before I leave home to make sure it's ok but like a moron, I didn't this time.
Put it in the lake and I went to start it and it only cranked over for a few seconds before the battery died.
The battery is about 4 years old. I had a bad rectifier a couple months ago and installing a new one appeared to fix my charging issue. I believe my voltage when it was running was at about 12.7v with the new rectifier. My old rectifier tested bad which is what lead me to believe it was bad.
I went home and put the battery on the charger. My charger said it was still at 12.3V and had "57%" charge left. My volt meter confirmed the 12.3V.
I inspected the battery terminals on the motor and the battery. I peeled back the insulation and found green corrosion. I cut off the connector ( I have more) and kept finding more and more corrosion. I wen't 5 inches back and still found green corrosion on every strand of wire. I should add that the connectors themselves were spotless as I just cleaned them a few weeks ago. The corrosion is just within the wire strands themselves.
I purchased the actual johnson service manual for it and read about testing the voltage from the yellow stator wire on the terminal block. This is how I would know that it is in fact charging the system correct? How many volts should I see? I'm assuming the voltage at the yellow wire should be about the same I am seeing on the battery while running correct?
Based on the picture below, do you think I should replace both the positive and negative cables from the battery to the motor? If so, should I see if that fixes the problem before I buy a new battery? Would corroded wires effect the "alternator" charging the battery?
Thanks for any help guys as usual!
