bad coil suspected
Similar to: http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=036753#000002 <br /><br />On 115 Hp Evinrude 1977, I suspect a bad coil(s). Or perhaps power pack?<br /><br />Running at set throttle (engine seems sluggish) - all of a sudden she takes off "like a bat out of hell!" She scares me so I pull the throttle back down and she's sluggish again.<br /><br />I took off all the coils and found the insulation to be melted on one only. <br /><br />Would one bad coil cause this? Or should I replace all 4 coils AND the powerpack just to make sure?<br /><br />Alocal repair shop charges $265 plus parts to go through the entire engine. All 4 coils ($29 ea) plus 1 powerpack at $90 is less than labor of the shop. <br /><br />Do you smell what I'm stepping in?
Barnacle_Bill
Re: bad coil suspected
I would replace that one coil and then go from there. It may solve your problems.
I was wondering what symptoms a single coil vs several bad coils would make? <br />Also whether the power pack would blow coils or vice versa?<br /><br />I will order a coil today and try it.
Walker
What you describe sounds more like carburator problems than a coil. If a coil is leaking definitely replace it, but I'd tear down the carbs and give them a good soaking and rebuild.
Solittle
Pull the plugs and check each one for spark. Spark should be a bright blue snap and jump around 1/2" gap. If the one with the melted insulation is bad or weak then you have confirmed the problem to be the coil.
blackwaterstout
I agree with Solittle. A spark check is free. Check the spark on all coils. That will tell you a lot about your electrical system.
will do this weekend. still have family hurricane evacuation refugees in house now. thanks all
mikeyzx2
you might not be able to get it to run if more than one coil's not firing. my '77 85hp has decided not to fire on 2/4 so it just about won't start and barely stays running if it does. just one coil dead will make it run a little rougher. my problem points to powerpack, as I got all new coils on mine and I've tested the stator with voltmeter. I got the OEM book if you need any technical info from it....it covers yours also
thanks Mikey, but I got my own manual and have some test meters but I may not have them all that the manual says I need.<br />My 115 starts fine. My symptom is ...WOT seems to be struggling, then all of a sudden it seems like the "rest of the engine" kicks in and off I go.....so fast - it scares me, so I pull the throttle back and I'm back to struggling again. <br />My engine doesn't even run rough. The only coil I have that looks like the insulation is melting is the only one where metal gets really close to the plastic. It must not be a bad coil (because the engine doesn't run rough at all) but I have one due in Friday so I'll put it on. Melting insulation will make it fail eventually.<br />I wish I knew if the power pack could cause my symptoms. I would change that out for slightly less than $100, but I know if I tear down the carbs I'll be in over my head and might as well hire it done..
