Bad coupler
BUMP
How do I go about replacing a bad coupler? I can't find it anywhere in my book. How much would you think it should cost me to have the repair shop handle it ( at there $85hr rates). Thanks
Don S
Re: Bad coupler
On what ?????????
Re: Bad coupler
(89' OMC Cobra 2.3L, Sunbird/corsica 175)
Ayuh,......
You've Already got 1 thread going about this Exact Same Problem,+ you asked the Exact Same Question there.....
Why are you starting a 2nd thread about the Exact Same Thing.......
It's already been Explained in your Other thread,....
The Coupler is bolted to the motor's Flywheel....
Pull the Drive,...
Pull the Motor,....
Change the Coupler,....
Then reverse for reinstallation......
BUMP
Re: Bad coupler
I'm a noob to forums, I know i had that last one but it was from a long time ago. I did know if it was still viewed or not.
Re: Bad coupler
Ayuh,.....
Regardless of the original thread's date,...
Every time it's posted on, it comes back up to the Top of page 1....
Generally speaking,... Any threads on page 1 are being viewed regularly.....
And,...
If the Questions are asked Clearly, with enough Info,.....
They'll be Answered....
BUMP
Re: Bad coupler
understood. Again i'm sorry. won't happen again.
