I have a 2003 four stroke 9.9 and it is having a rough time idleing. Carb has been apart and cleaned. It is good. Theses carbs have a electrical type of enrichment system on them. I dont have the manual for it so I was wondering how to test this to see if its good. If I unhook the wires it will idle just fine. Once you hook the wires up it wants to kill on me. The two wires run up to the flywheel and are a coil of wires to run the enrichner. When I check both the wires to ground I have continuity and I don't think I should. Running I have 24 volts at a higher rpm. I hope someone knows about this system and can help me out a little. thanks
