hootchieman
- Apr 9, 2003
- 16
I have a 2000 130hp johnson 90 degree looper.The quickstart function is not working properly,its always on,wont come off of high idle.The motor reaches normal operating temperature,the temp switch closes at about 98 degrees{tested in and out of motor so im sure about that}but quickstart remains on .If i jump the white/black wire coming from the powerpack directly to ground it should disable the function and go to low idle,but nothing happens.Should there be a voltage on that white black wire to ground.Possible bad powerpack? Thanks for any help
