Ok I got the boat weighed this morning 2660 pounds on the trailer. Tounge weight 180 pounds. Took measurements in the water 7 1/2 in free board to the engine well and 21 inches to the point of the bow (this is to the surface of the water). In the pictures you can see the nice matching seats.
All the wood under the side bolsters is rotted to nothing. The ones that are white with grey are the ones I have redone already.
The bove picture you can see the transome plugs are all loose, and when I drilled into the transom the wood appears to be saturated. Under the front seat
it had carpet wrapped clear around ant the water saturated the wood , you cant see much here but the wood under the carpet is pulpy
<br /><br />Hope to get a engine stand built today and maybe pull some of the seats out.
