luckyinkentucky
- Jul 29, 2007
- 462
I'm going to be welding together a bar-b-que grill within the next couple of days.
It will be less conventional than most of them you see, because this one will have a fire ring at the bottom for my fire to go. It will have a steel rod on either side with horseshoes welded at the top for a spit and hooks for utensils.
The problem I am running into is that I would like to use stainless steel for the grate, but it runs around $150 for a 24" X 36" grate. So, I was wondering what I could use instead of Stainless Steel. I would like to stick to the 'honeycomb' type grate instead of the slats or wire you see on most commercial grills. I will show you a picture of what I am going for , and see what you think. Like I said I can't afford stainless, so what should I use instead.
