Has anyone used Barnacle Buster to descale an outboard motor, and if so did you remove the anodes and what was your result?
I've got a 99' Honda that is still running great and not (yet?) overheating, but after 20+ years in salt is starting to show signs of build-up. Chunks of free floating scale inside the motor had begun blocking the pee stream on frequent occasion, and removing the lower unit and thermostat then flushing with large quantities of water removed a small pile of rubble and temporarily resolved the concern. But now only a few months later the problem is starting to reoccur so I'm thinking there are still chunks that I didn't get out and it might be a good idea to flush with some sort of chemical to actually dissolve the calcium deposits, IF it can be done without risk to the metal in the motor. After much youtube research, I get the impression that Barnacle Buster might be the most effective of the marine specific chemicals, but I'm unsure of the safety for an outboard. Lots of videos showing people using it, but no long term follow ups. Here is perhaps the most persuasive video in regards to the effectiveness:
