jsferra1
- Aug 10, 2007
- 31
Hello,
I'm back, I have a 1997 5.7L TBI V (I think it is a V TBI any way) from what I can see I don't have the Knock Control module on my dist and since it is not there I assume I don't have one since I can not find any place in the manual that says it could be here or there it only has it located on the dist.
So if I dont have one and if I ground the Pur/Wht wire out when I set the timming,RPMs and carb adj. and then remove it and when I restart it should the RPMs change or not and if not do I need to put it in base timming mode at all.
Also in the book it looks like I set the timming to 8btc but on the carb cover it has 10btc which do you think I should use?
The same thing with the plug gap the book has .045 but the carb cover has .035 ?
Thanks
Thanks
