Batter Switch Off, Still Power to Instrument Panel
Georgearia
With the battery switch off, I noticed I now have power to the instrument panel and ignition key accessory post. The only wire connected to power at the switch (not the COM) is to the auto bilge pump (As per wiring diagram 99 Sea Ray 260).
Could the battery switch be bad or is it possible for power to be somehow circling back to the instrument panel ? Thanks in advance for your input.
many times the auto bilge is hot wired direct to the house battery
tank1949
do you have a fume detector always on????
dingbat
Pull the cable (positive) to the switch off the battery.
If the problem goes away you have an issue with the switch.
If the problem persists, you have a "hot wired" circuit somewhere, typically the house battery
QBhoy
Hi. Is it possible you have two battery isolators. One for leisure domestic battery and one for starter battery ?
