shellone
- Jul 18, 2009
- 46
While running a BWA 8 meter rib with a Mercruiser 5.0 MPI in rough weather I had sudden power loss and noticed the voltage rise over 14.4. Throttled down to idle and immediately checked the battery to notice that the a ground connection looked loose. Tightened the screw and the voltage was back at 14.4. Unfortunately, the engine would not run at any throttle position but idle. Trying to go over 800 rpm I only had the consumption gauge go from approx. 6 to 10, 15. 20 liters per hour but without acceleration. Also disengaging the drive to neutral I could not get the engine to rev up. Felt it to be too risky to restart the engine since I was against a strong wind @ 4 miles from port. Only when moored I switched the engine off and after some moments of relief restarted the engine that worked just fine. The voltage was a stable 14.4 (it had been varying between 13.5 and 14.5 before), and the consumption was a stable 6.2 liters per hour (had randomly been jumping between 5 and 7 before). Would looking at the plugs help diagnosing or do I have to assume potential damage in some part of electronics ?
