Battery location
ahmincha
Hello all I have a 19 foot center console I was thinking of relocating the battery under the center console. Do I have to worry about the additional vibrations on the battery
Chris1956
Re: Battery location
You might consider a bit thicker battery cables, due to the longer distance (and the associated resistance). One size larger cables should be OK.
bruceb58
Of course you do. One of the reasons your batteries are located at the stern. Your battery will not last as long mounted forward. You have to decide if its worth it for them to not last as long. So what is the reason you are moving them forward?
joelybob
car batteries have all kinds of vibrations and they last alright
Texasmark
Not the pounding like you get in a boat. Cars have springs and shocks, and are usually run on improved roads.
On battery selection, OTR truck batteries are build tough because those babies take a beating too.
Mark
joelybob
Mark
well you need to come up here and drive on our roads. you would change your mind.
ahmincha
The reason I wanted to move it forward is there is a small area in rear where battery was kept that shared the fuel line I already routed the fuel line out of there. abut its small and hard to get in there . I want to put a battery shut off switch and would be more convenient under console. So I decided to leave battery where it is and route pos wire uo to console and back and put shut off switch in console its about twelve feet and I plan on using 2 gauge
bruceb58
What gauge are the cables you currently have? How long are the current cables? What engine/drive/outboard do you have?
ahmincha
Not sure on existing gauge they are Suzuki brand that go to outboard. Its a 140hp Suzuki outboard and the cables pos and neg together are about 4 feet from motor to where the hook to battery
oldjeep
Seems like there must be somewhere back by the battery that you could install the shutoff. This sounds like a ton of work for no reason. And 2 guage is barely sufficient for a normal short battery cable, at a 24 ft run I would be looking at 1/0 or 2/0
ahmincha
I will try to post pics of rear tonite. It is tight and i want to be able to get to things easily
