Battery powered pressure washer
Toyelectroman
Anybody use a battery powered pressure washer to do some light cleaning on there boat? If so does it help or should I continue to trailer my boat to the car wash? Currently I keep my boat on the trailer and there is no electic or water hook up where it is parked. My thought was I could just fill a 5 gallon bucket of water and siphon with the pressure washer to clean
airshot
Unless there has been a newer more powerful model come along the electric and battery powered washers were pretty weak. Sold all my electric and battery powered stuff and went back to a small gas powered washer. I have not saw a power washer that would siphon, they all needed water pressure from a hose, but...there could be things I haven't seen out there.
Scott06
unless it works better than the royobi one i got a few years back keep going to the car wash. I was pretty disappointed. It is more of a wetting machine than a pressure cleaner. cant see it doing you any good, although boat would go faster due to wallet being lighter
roffey
I have one and it does seem to work OK. The pressure is not great but does gets the job done. I mix a citrus in the bucket and it seems to clean off the hull well enough but be careful to wash off the cleaner.
motley crew
i bought the cheapest one on amazon rechargeable batt for lite cleaning it is awesome not a highpower thing but has been working for two years now and use it all the time car shows my boat etc 60 dol no complaints
Toyelectroman
I did end up buying the ryobi 600 psi battery pressure washer. It has worked out great for my needs. I fill two 5 gallon buckets and can wash my 20 foot boat. Again not really using it as a pressure washer but more as portable water sprayer
