BeerMonkey
- Jun 8, 2008
- 72
after fixing some electrical problems caused by the previous owner and installing a second battery i wanted to check to make sure the charging system is working and i dont think it is. with a volt meter on the - of the starting battery and the postive on the main lead going to motor(also tried on battery post didnt make a difference) at idle i get 12.6 at 3k rpm i get12.8 this is out of the water on muffs not in gear should it be around 13-14 v, what do i check first to see why its not working?
