Yacht Dr.
- Feb 26, 2005
- 5,581
Re: Bayliner 2252 cruiser restoration
Again..sorry for the late reply..been kinda tied up ..
You are talking about sealing and glassing the bulks First..then instal and glass tab ? or seal ..install..then glass the whole thing together ? Both ways will work. I like to resin seal..prep for glass..then dryfit..then Do ONE Lam session. ( without the 45 deg wood angle strips.
No worries .. your being looked after
.. Sometimes replies take longer then others because of our own schedules ( I wouldnt want someone feeling abandoned if I take a camping trip with the kids for 3 days
If your trans is Brown AND Moist .. then yea.. you might want post some pics of the results of your core samples ( I dont see pics of that ).
YD.
PS. Please Dont drill " as close as you can to the drain tube". If you want to check the trans at the drain plug..remove it ( It probably needs a reseal anyways ).
Thanks YD. Would you please take a look at pic # 2 & 5 above. I want to glass the stringers and completely seal them first and then glass the bulkhead into it to make sure that there is less chance for water to find its way into the joint. Will this method be an equivalent to the factory's and will provide the same strength for the joint? The other question is, the glass on the stringers has no adhesion to the wood. Is this OK?
Guys, I know my project doesn't measure up to some of the fantastic work some of you did here but it is work in progress and I really need your support. This question is important to me and I appreciate if you take the time to tell me what you think.
Also, Woodonglass wrote this yesterday in the Checking th Transom thread
"If you have access to the INSIDE of the transom, you should get down as LOW and as close to the Drain tube as possible. Using a 3/8 drill with a 1/4" drill bit drill into the transom no more than .3/4 to 1 inch deep. DO NOT drill all the way thru. Drill several holes spaced 6" apart and at various Heights on the transom. Check the drill shavings. If they are Light tan and dry. GOOD. If Dark Brown and WET or Powdery BAD. If all is well fill the holes with 3M 5200 Sealant. If BAD Replace the transom."
If you take a look at my transome core in the picture above you will find it brown and it is a little moist. Should I start worrying about my transom now?
YD.
