Hi,It's that time of year again where you guys are needed!! I'm having trouble getting forward/reverse on my 89 bayliner with force 125 o/b its as if the shift control isnt pushing/pulling the cable enough, when you select a gear you hear it trying to mesh but the cable on the motor needs another push for it to go in properly, this started to happen end of last season but I've just fired the motor up after winter and its worse than ever.<br />I need to know if there's an adjustment on the control lever unit? or what other possible way of solving this? as I dont want to pull the boat to pieces to get the controls out to find out there's no adjustment.<br />I know one of you guys will be able to help!!<br />Thanks
