Faztbullet
- Mar 2, 2008
- 15,931
Re: Bead blasting and fitting pistons
You always,always bead blast and do any prep work before you bore block as you do not want the cylinders to etch after its bored and honed. This way you find all the problems block has before you bore it as it could need replacing or welded. Since you already have bored it I would spray it down in Power tune or Carbon guard and let set over night to soften up carbon and pressure wash. Use a round toilet brush in the cylinders with a stronger cleaner like Purple power several times until you can wipe bore with a white paper towel and no gray residue is remaining, then soak cylinders with a water displacing lube like WD40 to prevent rust. Ask your local dealer if you can rent the ring compressors or set the crank for you, with proper compressors I can set a crank in about 10 mins, that includes installing compressers and dropping all 6 pistons and crank at 1 lick. Pm me as if your close(Tn) I can set it for ya...
