bruceb58
- Mar 5, 2006
- 30,792
Re: Bearing buddies keep falling off...
The best way to adjust the bearing nut is to tighten it while spinning the wheel...some say around 20 ft lbs. Then back off the nut and then just hand tighten it liniing up the cotter with the closest notch or hole depending on what you have. There should be little or no play when you shake the wheel.
