Beef jerky @ home
lowkee
Well, it is that time. I have already cut back on outside costs by restoring my own boat, brewing my own beer and now I have begun producing my third necessity on my own.. beef jerky! :)
Anyone else tried or doing this? It is quite easy and came out pretty well, and for about 1/3 the cost of store bought.
If you're curious to try your own jerky, here is a quick recipe:
- Buy a 6lb beef roast
- Slice it into 1/8-1/4" slices
- Remove the fat as best as you can (fat tastes icky in jerky)
- Marinate it overnight in whatever flavorings you wish (we used Worcestershire, fresh onion, fresh garlic and some liquid smoke)
- Cut some window screen (the kind you would use on a screen door) to place over your oven racks
- Lay the sliced meat on the screening
- Roast in the oven @120*F for 12-16 hours or until it tastes like jerky .. I know, taste testing is such a chore!
- Be sure to prop the oven open with a jar lid or similar to allow for moisture to escape
We noticed the jerky pooled up with the oils from the meat, so we may put a paper towel under the screen to absorb that next time, but otherwise it came out really tasty and stringy, just like normal jerky!
Boating, beer, beef jerky. Life is complete! :D
We used vinegar in our initial batch and it came out zesty, in a bad way, so I'm hoping for some sweeter recipes.
Anyone else have a good recipe for marinade?
tallcanadian
Re: Beef jerky @ home
Boating, beer, beef. Sounds like you got your B's in line. Good combination though for sure.
Bob_VT
Lowkee Yes I am a huge fan..... you have a PM
JRJ
We make it in a dehydrator. Marinate overnight in 3 parts low sodium soy sauce to 1 part liquid smoke (hickory or mesquite).
Make enough to thoroughly cover meat (we use London Broil or venison or elk) in a non metallic container. Refrigerate 24 hours, turning occasionally.
Remove and blot w/paper towels. Coat with black pepper to taste.
Rotate racks until done.
Simple and tasty.
rbh
Simple and tasty.
"What no moose" those swamp donkeys are the best.:D
JB
I use a stovetop hot smoker and either hickory or mesquite chips after the marinade, then put it in the oven at about 170 for 3-5 hours.
Works very well for venison, too.
kenmyfam
Going to have to try it myself now.
Until today I have always bought it and hated the price.
SuperNova
I use a dehydrator and make my marinades "off the cuff" depending on how my taste is running at the moment. A good dry rub works out great too. Also, if you want to go really inexpensive, you can make jerky out of ground meat, like hamburger. Then I can shape it flat like normal or round like a slim jim. I'm always trying to hit up my hunting buddies for some venison to dry, in season.
xxxflhrci
I've made it at home. I usually use ground meat and a shooter. Meat is no problem. We have a beef cattle farm and I have a brother who kills no less than half a dozen deer a year.
I've also bought it at steep discounts and stocked up. A couple of years ago, I found 360ct. boxes of Super Slim Jims for 20 bucks a box...I bought 1100.:D
A few months ago, I went into Dollar Tree and found 4 ounce bags of jerky for a buck. Those are the big bags that are normally about 5 bucks. I bought 100 bags.
HopeSheFloats
Yep, make it here at home as well....we run a toothpick thru one end and 'hang' them from the oven racks, and use a drip pan to avoid a mess{don't ask how I know this...lol} we go 200 degrees for 4 hours, the meat gets harder after it cools{if you can wait that long :D}.
For a marinade, heavy{to your own taste} black pepper & 1/4 cup tamari soy sauce, 1/4 cup of your favorite steak sauce, teaspoon of liquid smoke{hickory}, some onion powder, salt, and a tablespoon of worcestershire sauce...Mmmmm
i386
I have a dehydrator that I bought specifically for making jerky. I forget which cut of meat I was buying at the time, but I recall it being expensive. I say expensive because after it shrinks there's not a whole lot left compared to what I bought. It sure was good though. I'd like to try it again sometime perhaps with a cheaper cut of meat. IIRC I just used a little salt, pepper, worchestershire, Coca Cola/Dr Pepper, liquid smoke and sometimes Tobasco.
I used to like venison and that would be a good option except something happened to my tasters. Wild game grosses me out now and I don't know why. That's one of the reasons I don't hunt anymore...:mad:
dlindeblad
Around here in Maryland we are allowed 12 deer. This equals six deer from my original home in upper Michigan. I have about 100 lbs of venison burger each year. I go to bass pro each season and stock up on powdered seasonings and just mix w/ a little bit of water before mixing in the burger. I prefer pepper jerky seasonings.
I have one of those devices described by a poster before that looks like a caulking gun. It came w/ two differernt tips so if I was making two flavors I could tell the difference visually. Now after I squeeze them out on the racks I place them in my Cheftain smoker with some Jack Daniels wood chips from their used whiskey barrels. After running on that smoke for a few hours (as they are bigger chips) I switch out for some hickory shavings. They usually sit in the smoker for 10-12 hours. Be sure not to over smoke the jerky or it will taste like licking the bottom of a pot belly stove.
mike64
I tried making jerky for the first time a few weeks ago, from venison strips. I marinated it in a soy sauce-brown sugar-black pepper mix, and I hung the strips using the method Kenny mentioned (with shish kebab skewers instead of toothpicks). 5 hours in a 150 degree smoker with hickory and applewood. Turned out terrific! I want to try it with beef too now.
thurps
I make it pretty much the same way as JRJ except he forgot the cayenne pepper. We slice up a turkey about every other time and jerk it. Other varieations are using ground beef or ground turkey and flatening it out between two pieces of waxed paper. I haven't quite mastered fish yet but by adding a little olive oil to the mix it seams to flavor it better. Now I have to go out and make some more.
mike64
If you're making jerky out of beef, what cut of meat works the best?
Bob_VT
Start out with a bottom round roast which is a cheaper cut and works fine. Trim the fat and slice it into 1/8 - 1/4" slices. ;)
SuperNova
Ummm...that's 22,000 dollars worth of slim jims?
Something wrong with my math? I mean I like slim jims and all....but 22,000 DOLLARS!!:eek::eek::eek::eek: You are a slim jim GOD!!
