Been a little cold.
office building cools OK ish in the summer, doesnt heat worth a crap. its under 60 in my office.
JonBoat55
Branford Point in CT, frozen solid past the channel. Housatonic River also frozen almost solid. Hasn't looked like this for almost a decade
airshot
I've seen a shocking amount of cracked outboards last few years... and I just can't help but wonder how people manage that.
Many folks leave their outboard tilted up over the winter, see lots of them around here in NW Ohio.
Pmt133
You'd think that would only be the lower cracking though. I'm talking whole power heads blown open... like glorious levels of freeze I'd think you'd have to try to achieve. :LOL:
airshot
Once the exhaust opening freezes shut....no place else for water to drain. Many never drop the motor down to let it drain before tilting it up. I have saw a few that left their boats in until well past seasons end, figuring the water would keep the lower unit from freezing....but the block is still susceptible to freezing !! No explanation for some folks reasoning......
Jeff J
I run mine up and down a couple of times to drain it every time I pull it out of the water just in case I don’t lower it when I get it home. I mine is up now. Shouldn’t be but I haven’t been around the boat since August.
arks
Been crazy cold here on the Chesapeake. I typically leave the boat in the slip all year, and if it ices up it’s only a thin coating. Not this year!
Can’t see it, but my de-icer is doing its job off the finger pier. The vast majority of the boats still in here do not have any ice protection.
dingbat
But, But, But....outboards are self draining even with the foot tilted up......lol
Outboards have an open loop cooling system. The only thing keeping the block from draining is not storing the motor verticaly, possibly a plugged thermostat and/or a loss of gravity.
Have left the foot in the water to prevent any moisture in the lower unit oil from freezing up and cracking the foot for years. Never had an issue
except outboards with oil coolers or charge air coolers where the plumbing dips
DeepCMark58A
I will say the sun does feel stronger, the rood clears off pretty fast after it is plowed now.
Lou C
we reached a balmy 31*F here today, and sunny.
might get some snow over the weekend then back to the deep freeze with highs between 15-20. So the snow we had last weekend will stick around a good while.
dingbat
Any idea which outboards?
Not having any luck finding an owner’s manual that gives instructions on winterizing the cooling system
Mercury Verado (supercharged) and the optimax (oil cooler)
airshot
We have a few that do that up here in Lake Erie, gotta get that last Walleye of the year... A few have ended up with frozen blocks and tilting the out board up high enough and it will trap water in the exhaust hub and cause damage. Seen a few in my years..
