Re: Been advised to fit trim tabs
wait, you can just walk in here and post pictures of that thing without a little detail! Looks like fun!!! I've seen old versions of that type of boat, basically a precursor to a modern PWC, but that thing is both a little larger than that, and new...
Anyway, I don't know if I'd put tabs on that... It looks like it handles fairly well already, I'm assuming the engine has trim? And as the previous post mentioned, get rid of the tail and try it again... Worst case, relocate your battery to the front.
Finally, even if you did want to put tabs, not going to happen on that hull... The angled part is too angled, and the part that is vertical is too close to the motor, it would hit the tabs when you turned.
