beeping from under dash
bruce 42
Last night I bumped a stump and now there is a beeping sound from under dash, the motor bumped up, is there a reset ?
MudSkunk
Re: beeping from under dash
depends on how hard you bumped it. motor warning tones can mean many things depedning on the tone. anything from the motor not getting enough coolant to not enough lubrication. you should check the manual for your particualr motor and try and match the beep withthe problem. since it is liekly a motor issue you might repost in the appropriate motor forum with more information.
