depends on how hard you bumped it. motor warning tones can mean many things depedning on the tone. anything from the motor not getting enough coolant to not enough lubrication. you should check the manual for your particualr motor and try and match the beep withthe problem. since it is liekly a motor issue you might repost in the appropriate motor forum with more information.
