Beginner
Chasefamily
Does this look OK? Was planning to sand it down and put on one more layer?
MikeSchinlaub
Master Chief Petty Officer
I can't tell from the pics, too far away. It looks like you just layed a square patch directly over some damage? Any grinding before?
The closest one looks like a hole. Did you fill it in, if so with what?
Chasefamily
The first one is a hole. I filled it in with liquid resin. I beveled around the hole in top and bottom side and grinded all around it with 40 grit to hopefully create a good bonding surface.
