Belts on 89 OMC 4.3
av8or09
I have a 89 Sunbird eurosport with a 4.3L OMC/Cobra. I replaced the belts when I bought this with the same size that was on it. My problem is I think the belts that where on it are to narrow. They sit way down in the pulley grooves and wear excessively. Does anyone know where I can find a cross-ref for belts using OMC #'s. Or better yet, know which belts I need (I have power steering also, so I need both belts) I have tried NAPA and about every belt manufacturer website I can find. My original OMC parts list doesn't give belt sizes, just OMC #'s.
Don S
Re: Belts on 89 OMC 4.3
If the pulleys are all rusty, that is why the belts are too narrow. The rust acts like sand papeer and wears down the belts in no time.<br />If they are real rusy, replace them and keep them dry. <br />You may also be able to take them off sand, wire brush, sand blast or what ever to make them smooth and repaint with a quality paint. RustOlem works great. Allow to dry for a day or so and but the new belts on. You will be amazed at how long the belts will last.
av8or09
Thanks Don S. I just realized I had not replied to this post yet. I did find out that the belts were to narrow and the pulleys were also rusted some too. I did as you said and wirebrushed and repainted them. I replaced the belts with the correct size (found it on the GATES x-ref) and everything is lovely! THANKS AGAIN!!
