Bend prop??
raamw
I have a 3 blade 9.5 X 10 alum prop and each blade id bent slighlt different from the other, is there any trick to get them inline with each other?would heating them work<br />Or does this have to be done professionally?
Dhadley
Re: Bend prop??
Like they say -- don't try this at home........
TilliamWe
Banned
Re: Bend prop??
No "trick" to it really. Just skill, and the right tools. Things like a lathe, and pitch blocks. Stuff a professional has at his/her disposal.<br />If you just had the tip of 1 blade dinged, I'd say, "sure use a ball peen hammer and a wood block". But what describe needs to fixed by a professional!
WillyBWright
Re: Bend prop??
I use a mid-sized plastic deadblow hammer and a large vise as an anvil. Do a little at a time. You can eyeball it better than it is right now. To do it right, you need the right stuff. But nothing says you can't make it better than it is.
raamw
Re: Bend prop??
I took the advise and took out the hammer, I had a little problem till I use a vise on a heavy bench to stop the movement, I believe I got the prop back to uniformity, took a little time but like most people I have a lot more time than money Thanks
