Hi Guys
I have 1998 Searay 190 with a 4.3L Mercruiser Engine and an alpha one outdrive. The serial no of the drive is 0F095817.
I recently hit a rock with my prop and not only did i damage the prop but i also bent the shaft.
So guys what are my options here?
1. Can i replace the shaft? If so, i take it a i need to remove the lower unit from the upper drive unit to get the prop shaft out.
2. Can i straighten the shaft? The shaft is visibly bent when you rotate it!
3. Do i need to replace the complete lower unit?? I hope not! If so i'll be off the water for some time as my budget will not allow this i'm afraid...
I started to take a look at it last night and removed the prop and parts as far as the bearing carrier (item 58 in the manual). I wil need to borrow a suitable pullers as my own isnt long enough to remove the bearing carrier.
Any advice would be greatly appreciated.
Thanks
Limk
Thanks
Limk
